16 Users Online (14 Members):
Forums >> Revit Structure >> Tips & Tricks >> Shared parameter from View to Sheet
0 Posts No Rating |
Hi guys,
I have been trying for some time now to figure out a way of making a shared parameter assigned to a view that will show up on the sheet also. I want to asign a custom text to the view and make it show up when placed on a sheet(similar to the scale or name of the view)
Does anyone have an ideea about how to make this thing happen ?
Thanks
The only family associated with views is the view label.
0 Posts No Rating |
hi,
i have the some problem, if you did find a solution please telle me.
thanks
0 Posts No Rating |
If it is just text, you can achieve this by using a Shared Parameter (SP)
Annotation family: Create the SP as text > Select View Title in Category and Parameters > Insert into Revit Project file
Project Parameters: Add SP in > select Category: View
Viewport type: Create a new Viewport type > Select title as your family
Edited on: Fri, Nov 24, 2017 at 12:39:39 AM
I have a solution for everyone, I made a video for how to use and manipulate Revit's Schedules, in particular with custom parameters, sorting, grouping, counts, and filtering: https://youtu.be/JCrEhK6MS8A
-Enjoy-
Dan
Edited on: Fri, Oct 9, 2020 at 9:05:32 AM
Edited on: Fri, Oct 9, 2020 at 9:06:27 AM
Edited on: Fri, Oct 9, 2020 at 9:06:48 AM
Referencing a Shared Parameter in a Family parameter formula. |
Thu, Jan 29, 2015 at 1:26:24 PM
Instance Shared Parameter?? |
Fri, Jul 11, 2014 at 2:49:26 PM
Shared Parameters for Browser Organization |
Fri, Nov 9, 2012 at 11:39:27 AM
Editable Text on Sheet without shared Parameter (simple way) |
Mon, Oct 27, 2014 at 3:38:10 PM
adding a parameter to "view-title"? |
Thu, Aug 2, 2007 at 4:11:24 PM
