Forums >> Revit Building >> Technical Support >> Phases
Mon, Aug 25, 2014 at 2:08:26 AM | Phases
JoeHands
Hey,I have recieved a model from a client. Its divided in phases i.e. "Existing" "Demolition" and "new construction". The "new construction" phase is useless and i want to delete it. But every time I combine it with the other phases, the "new construction" phase "wins" every time. How can i delete it an all the content without changing the other phase?
Mon, Aug 25, 2014 at 7:32:39 AM | Phases
Why is new construction useless?
Is it that you now want everything to be existing?  If so, then set the view to show only new, window everything and change it to existing.  Your demolished items might have been demoed in new (should have been) so you will have to address those as well.
Tue, Aug 26, 2014 at 2:28:06 AM | Phases
JoeHands
Hey.Thanks for your reply.The "new construction" phase is created from an old design. The actual design which is going to be build is not modeled yet. So i would like to just keep the "existing" phase. Then delete "demolition" and "new construction". And then create a new "Demo" phase and a new "new construction" phase from the "existing".To set the phase filter to "show new" in "new construction" doesn´t solve the problem because the phase is still there.Btw. English is not my mother tongue so I hope its understandable what I have writen. Thank you.
Tue, Aug 26, 2014 at 7:25:06 AM | Phases
OK.... Why don't you:
  1. Set the view tio new, window and delete everything that is new.
  2. Remove the demo from all items that were to be demoed.
Having the new phase is no problem because this is where you will create your new design.
You can never delete the new and existing phases.  Just don't use them if you don't want them.
Capabilities to isolate phases
Tue, Nov 28, 2006 at 5:43:02 AM
Demo Plan with multi phases
Tue, Jul 28, 2015 at 7:34:43 AM
Showing multiple phases in one viewport
Tue, Jun 16, 2009 at 8:02:56 PM
3D View of Phases
Thu, Feb 24, 2005 at 5:51:44 PM
Ghost Phases
Mon, Mar 24, 2014 at 5:08:46 PM
12
Page generation time: 1.0125
