Forums >> Revit Building >> Technical Support >> doing a night rendering
Tue, Mar 7, 2006 at 7:34:37 AM | doing a night rendering
hammer87
hammer87 Avatar
3 Stars: 4 Votes
i wanted to know how to do a night rendering.
Tue, Mar 7, 2006 at 9:25:54 AM | RE: doing a night rendering
neobudda
although ive never done a night rendering, I noticed that when you have your frame and everything set up, you can go to the browser bar under rendering and there is an option that says Lighting... with a light bulb beside it, anyway, if you go into this, you wil have a light source called sun, to the right of that is a box with a check mark in it. im guessing that if you uncheck the box, it will turn the sun off, creating a night scene. but ill asume that you will need to put in lamps and such for the rendering to work
Tue, Mar 7, 2006 at 11:19:18 AM | RE: doing a night rendering
hammer87
hammer87 Avatar
3 Stars: 4 Votes
yea i have all the lights i want, but when i click go, and wait, the scene is still all black, and i made sure the lights were on.
Tue, Mar 7, 2006 at 5:29:02 PM | RE: doing a night rendering
gautamrs
gautamrs Avatar
5 Stars: 3 Votes
please explain your setup in detail.... lights are placed where, how many sources, is your sun turned on or off and most importantly, have you checked the envirnoment setting. I need to know your initial setup and i can probably help you from there.....
Wed, Mar 8, 2006 at 11:32:11 AM | RE: doing a night rendering
hammer87
hammer87 Avatar
3 Stars: 4 Votes
well i got now. thaks for the help
Wed, Mar 8, 2006 at 12:51:38 PM | RE: doing a night rendering
PopcornEaterMan
I'm having the same problem. Can you post your solution?
Wed, Mar 8, 2006 at 1:15:10 PM | RE: doing a night rendering
hammer87
hammer87 Avatar
3 Stars: 4 Votes
all did was that i turned the sun off and turned on all the lights i had.
Mon, Apr 27, 2009 at 12:16:23 PM | doing a night rendering
Hiscutt
Or you can go to Advanced Model Graphics ans turn the sun to a brightness of zero. It will render all black, and then you have to adjust the exposure accordingly....Hope this helps
How to render with night mode on revit architecture 2011
Mon, Dec 5, 2011 at 3:42:41 PM
Revit to 3ds night render
Thu, Jul 30, 2009 at 1:26:02 PM
revit night rendering
Wed, Jul 20, 2011 at 11:47:02 AM
Night Scene Render
Wed, May 2, 2007 at 9:21:18 PM
night rendering in 2012
Mon, Apr 23, 2012 at 2:56:19 PM
Page generation time: 1.9869
