22 Users Online (20 Members):
Forums >> Revit Structure >> Technical Support >> How to globally adjust Revit lineweights in section
Hi -
I am attempting to set up some office standards, and I have updated the object styles in our template to make elements to look how we'd like them to look in plan. My problem is that - for girders for example - I have the cut and projection lines set to 6 to have them show up very heavy in plan. When I cut a section, though, the girder outline is now way to heavy. I tried changing the "cut" line weight so that it would be lighter when cut in section (even though this wouldn't necessarily solve my problem, as sometimes section cuts also show a projection of perpendicular beams framing into the side of cut beams, and I'd want those both to look the same). However - changing the "Cut" lineweight in object styles appears to have no effect on the girder in my section cut (which I don't understand - I would think that updating "Cut" lineweight from 6 to, say, 2, my section would be update and show the girder outline with a lighter lineweight??).
Of course, I could just override graphics in view for every section I have to cut, but I was hoping that there was an easier/ more global way to make this change. If not, the next best thing I can think of is to create a view template that I'll have to use every time I cut a section?
Thanks for your help!
Edited on: Wed, Aug 20, 2014 at 7:09:43 AM
View templates.
NOTE: Even though you think this is a girder, the structural framing cut controls this line.
Edited on: Wed, Aug 20, 2014 at 8:03:08 AM
Yes, that did it - Thank You!!!
Lineweights Issue |
Thu, Nov 17, 2005 at 6:05:35 PM
SHOW PRIMARY & SECONDARY BEAMS WITH DIFFERENT LINEWEIGHTS ON A SECTION |
Fri, Nov 12, 2010 at 7:07:47 AM
Lineweights Question |
Wed, Aug 3, 2005 at 4:03:11 PM
Revit lineweights |
Wed, Jan 28, 2015 at 9:31:49 AM
Revit Lineweights not printing correctly |
Fri, Jun 14, 2013 at 1:27:49 PM
