Forums >> Revit Building >> Technical Support >> panels dont update on Curtain wall length
Fri, Aug 15, 2014 at 4:41:27 PM | panels dont update on Curtain wall length
Warchitect
4 Stars: 5 Votes
Got two curtain walls forming a corner window. had to adjust the underlying wall. and when I stretched the C Wall to match the new length the glass panels didnt change with it. cant figure out what I did, or how to get the glass to stick with the curtain wall line...
Sat, Aug 16, 2014 at 8:20:44 AM | panels dont update on Curtain wall length
Not enough information.
Is this CW an automatic one?   In other words, are the panels and mullions as well as the spacings set in the description?
Where are your grids for this CW?  Look at it in elevation.
It may be that you just have to put a panel in there.
Also - does this CW have a sketch on it?
Curtain wall panels with an arrayed profile
Thu, Mar 13, 2014 at 3:02:35 PM
curtain walls make like partition walls
Sun, Oct 26, 2008 at 9:23:37 AM
11
Curtain wall panels following profile
Wed, Oct 12, 2011 at 8:41:57 AM
Turning certain curtain panels into spandrel panels
Tue, Dec 3, 2013 at 1:59:47 PM
Can Adaptive Panels Be Used in A Curtain Wall
Mon, Jun 9, 2014 at 1:49:36 PM
Page generation time: 0.7102
