Forums >> Revit Building >> Technical Support >> Raking curtain walls, adding tags to Shop Front glazing
Mon, Mar 6, 2006 at 10:14:01 PM | Raking curtain walls, adding tags to Shop Front glazing
goum
I need to know if anyone knows of a quick way to do curtain walls that rake vertically. At present, I'm using the "Curtain System by Lines" command. This has been a little time consuming as I've needed to draw model lines at the required levels and offsets for the base and head. I then create the curtain wall. If any changes to the building height happen, the wall does not adjust with it. Can this be recified? Is there a quicker way to construct them? Also, the building I'm currently documenting has heaps of shopfront type glazing, I need to apply tags to this glazing and be able to add to the window schedule, is this possible? Any help will be greatly appreciated.
GN Brisbane, Q Australia
Tue, Mar 7, 2006 at 1:11:57 AM | RE: Raking curtain walls, adding tags to Shop Front glazing
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use a mass then create curtain wall by face. Then if the height changes, adjust the mass and select the recreate option on the curtain wall and it will automatically update to the height change. To tag the panels as windows, swap them out for curtain wall windows. HTH. Post edited on 2006-03-07 01:13:08
Tue, Mar 7, 2006 at 9:35:58 PM | RE: Raking curtain walls, adding tags to Shop Front glazing
goum
Hey, Mr Spot we're practically neighbours. Thanks for you quick response, I'll try what you said.
Curtain wall shop front
Fri, Apr 3, 2020 at 2:42:51 PM
Glazing in curtain walls
Thu, Dec 10, 2015 at 7:38:15 AM
Curtain wall glass in front of mullion
Wed, Sep 24, 2025 at 5:54:30 PM
Curtain system > glazing panel matherial
Mon, May 28, 2012 at 1:02:14 PM
Glazing in roof
Wed, Oct 17, 2007 at 5:52:52 PM
Page generation time: 0.5234
