Forums >> Revit Building >> Tips & Tricks >> Floors and Floors again....
Fri, Aug 15, 2014 at 2:46:41 AM | Floors and Floors again....
Reddrev
I watched a Revit tutorial (Lynda.com) about floors...   The video explained using two floors, one for structure and one for the "finish"  as finishes can change from area to area etc.   This does make sense, but it got me thinking....   What is the best workflow for floors?  Use a different floor on top of a "structural" floor, or split the surface etc?
In revit terms, what is the difference between a structural floor and a standard floor?
When creating floors and roofs etc, I switch to black background, so much easier to see my errors!  Be good to be able to toggle via a keystroke,  black and white screens, as I find my self switching a lot between these two.  Maybe an external macro would do the  trick
Thanks
Fri, Aug 15, 2014 at 7:28:22 AM | Floors and Floors again....
What do you want from your model?
If you want quantities then split face is bad and thin floors for finishes is best.
I think using a black background doesn't help with anything ... but then maybe you are not using black lines but trying to do CAD.   Don't do that.
Mon, Nov 25, 2019 at 12:46:41 PM | Floors and Floors again....
hanbyjm
Using a black screen helps with less strain on my eyes.  I make 2 floors with my models.  1 is the slab and the other is the finished material.
Grouping Floors
Mon, Aug 22, 2005 at 3:47:49 PM
Joining the Geometry of two floors
Wed, May 14, 2008 at 5:46:12 AM
copying floors up
Sat, Jul 25, 2015 at 7:49:27 AM
Dead horse still kicking - walls and floors strategy
Tue, Oct 2, 2007 at 1:36:25 PM
Progataing property lines to floors
Fri, Mar 18, 2011 at 4:25:43 PM
Page generation time: 0.8416
