Forums >> Revit Building >> Technical Support >> Material Catagory
Thu, Aug 14, 2014 at 12:52:31 PM | Material Catagory
Warchitect
4 Stars: 5 Votes
So if you notice. the material for Wood - painted is there and has the "glass" as its catgory, all the others are good. this has happened a couple times in my materials list, and I can't figure out where I can change it to make it in the same catgory as wood. can someone point me in the right direction? thanks in advance. see pic
M
Thu, Aug 14, 2014 at 1:22:47 PM | Material Catagory
I believe that this is set by where you create the material.  Someone must have duplicated a glass category material to make that wood.
Thu, Aug 14, 2014 at 3:22:17 PM | Material Catagory
Warchitect
4 Stars: 5 Votes
Thanks. I guess I need to make the material again properly.
thanks again Hub
Fri, Aug 21, 2015 at 4:29:44 PM | Material Catagory
Warchitect
4 Stars: 5 Votes
Sorry for the zombie rez.
but Ive made a new material, and its "uncatagorized"....where is that spot where you assign the catagory?
Parameter Formula Help Needed
Thu, Oct 15, 2009 at 10:47:50 AM
Visibility Problems
Mon, Mar 13, 2006 at 5:15:59 PM
"Family is not of the Correct Catagory"
Thu, Feb 17, 2005 at 11:59:43 PM
is there/can there be a Halftone macro?
Tue, Jul 24, 2012 at 1:14:24 AM
WALL CUT (openings) MATERIAL
Sat, Sep 28, 2013 at 10:56:04 AM
Page generation time: 0.2919
