Forums >> Revit Building >> Technical Support >> calculated value - cost
Wed, Aug 13, 2014 at 11:13:02 AM | calculated value - cost
joe5676
Using revit 2014
I'm trying to get total cost #'s by occupancy and am having problems with the calculated formula.  I'm using areas as the basis for the schedule with name and area as my parameters.
I'd like to do something like: occupancy type * area * cost per sf = total cost
I can do a blanket calculation that multiplies all areas by a square foot cost, but i am not having luck filtering the name parameter.  For instance we have residential, common spaces, amenity, parking, etc.
Can anyone advise on the IF function so I can define by the name of each area type and assign a unique cost to each of those types?
Thanks very much for any help!
Wed, Aug 13, 2014 at 11:18:35 AM | calculated value - cost
Read this whole thread .... I think you are having some of the same issues:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=33492
Calculated Values
Mon, Mar 3, 2008 at 11:01:17 AM
Material cost per sq ft formula
Mon, Sep 21, 2009 at 9:06:24 AM
Material Cost Analysis in Schedules
Wed, Jan 13, 2010 at 6:55:37 PM
Calculating cost of Nested Families in families in projects - Custom Kitchens
Wed, Nov 13, 2013 at 4:09:28 PM
Cost Modelling Schedule
Fri, Jan 30, 2009 at 10:05:09 AM
Page generation time: 0.3913
