Forums >> Revit Structure >> Technical Support >> Multiple beams to column connection
Wed, Aug 13, 2014 at 10:50:35 AM | Multiple beams to column connection
havoc1
Hello All,
I'm working on a multiple beam to column connection, have reviewed several posts on here referring to "beam to column" connection but have not found what i'm looking for as of yet. In my case I have three modified beams that i'm trying to attach to an HSS Column. I have one attached to the column but when i try to move the other two towards the column the other one moves back as if they're polar opposites, I also lose the cut on the bottom of the beams. I have tried pinning the beams but no luck there.
Anyway, i have attached a some images, i'm using revit 2014.
Wed, Aug 13, 2014 at 11:16:37 AM | Multiple beams to column connection
No images.
Did you know that you can cut beams using reference planes?
Wed, Aug 13, 2014 at 11:17:10 AM | Multiple beams to column connection
havoc1
Need Help on Sloped Beam-Column Connection
Fri, Apr 29, 2016 at 1:50:43 PM
Beam Column Connection
Fri, May 27, 2011 at 10:12:02 AM
Column to diagonal beam/brace connection problem
Fri, Apr 23, 2010 at 4:40:24 AM
Concrete Beams not extending to Column C/L
Wed, Jan 28, 2009 at 8:26:37 AM
connection problem
Thu, Jan 28, 2016 at 2:19:22 PM
Page generation time: 0.7623
