32 Users Online (30 Members):
Forums >> General Discussion >> Revit Project Management >> Tagging Default Elevation Parameter for Face-Based Families
Hello all,
I'm trying to figure out if I can tag the default elevation parameter for face-based families. The firm I'm working for really wants this to happen, and I'm struggling to find an answer.
Is this possible? If so, how? If not, is there a workaround?
Is it possible to have the tag read in inches, not feet?
Thanks in advance for your help!
A "default" elevation - no.
A read elevation after placement... maybe by using a group.
Elevations can have multiple types with different properties.
From your HELP: http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-4B2E9197-8BC9-4F4E-ABC3-EF58A9D87AD0
Apologies, I didn't write the correct title in the post.......
I'd like to tag the Elevation parameter, not the default elevation parameter.... As in, the elevation of a face-based object from the reference level (in inches if possible)
Tags read shared parameters in families. I don't know if this can be a reporting parameter or not.
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-DBC31A77-813A-47E0-8EFA-B6D821F75EDB
As I said before - measuring units are up to you.
Scheduling Problem with Face Base Families |
Tue, Jul 15, 2014 at 8:59:16 AM
Converting Ceiling Based families to Face Based Families |
Tue, Jun 12, 2018 at 7:13:41 PM
Face Based Component - Default Load Settings |
Mon, Feb 15, 2016 at 10:23:49 AM
Plan annotations for face based families |
Tue, Feb 8, 2011 at 8:59:45 AM
Tagging offset parameter |
Tue, Jul 27, 2010 at 3:47:47 PM
