Forums >> Revit Building >> Technical Support >> Distance Inquiry In Imperial On Metric Project
Fri, Aug 8, 2014 at 8:54:56 AM | Distance Inquiry In Imperial On Metric Project
SRobbins1977
Hello Revit Users,
We have a project from China in Meteric; which it needs to be in. However our US based designers want to do DI (Distance Inquiry) commands in Imperial so they have a better sense spacially. It's been a long while since I have checked to see if this is a feature in revit and google searches are pulling up anything but an answer.
Is anyone aware of a way to do this with out changing the whole project over to Imperial?
Thank you,
~SR
Fri, Aug 8, 2014 at 9:05:58 AM | Distance Inquiry In Imperial On Metric Project
Project units set this but that may also affect dimensions in the project depending on their settings.  That is an easy fix, however.  Simply edit the varied dimension settings to metric instead of project units.
showing metric and imperial elevations
Thu, Jun 3, 2010 at 3:34:46 PM
Imperial metric question RAC2009
Fri, Jan 9, 2009 at 11:35:51 AM
Metric Viewport in an Imperial Unist based project
Mon, Aug 11, 2008 at 9:16:58 AM
Change from Metric to Imperial
Sun, Feb 17, 2013 at 9:26:03 AM
Imperial and Metric sheets and views
Thu, Dec 16, 2010 at 3:32:05 PM
Page generation time: 0.7774
