Forums >> Community >> Newbies >> Visable Line that doesnt print - Title block
Thu, Aug 7, 2014 at 6:34:00 PM | Visable Line that doesnt print - Title block
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Hey guys just need a line that I can see but doesnt print on my title block. Tried a few couldnt find anything that worked.
Revit 2018........
Fri, Aug 8, 2014 at 7:42:06 AM | Visable Line that doesnt print - Title block
All lines except invisible lines will print if they are on in VG.  Invisible lines in titleblocks will become visible when you roll over them.
Tue, Aug 12, 2014 at 10:49:38 PM | Visable Line that doesnt print - Title block
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Dam wanted one that shows so I can see what I can fit on my page.
Revit 2018........
Wed, Aug 13, 2014 at 7:36:23 AM | Visable Line that doesnt print - Title block
Use guide grids
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-D0ADD92C-90A9-4F54-84C7-5D050453B032
This is an example of a typical problem with postings.  Most users, just like clients, ask their questions based on a solution they know.  That's why we ask why.  The "why" is important because the poster doesn't know enough about the program to frame their question only by their knowledge of process.
After all these years, I still don't know either.
Wed, Aug 13, 2014 at 7:01:35 PM | Visable Line that doesnt print - Title block
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Thanks for your help again WW! Will have  read. But if you don't know.... there is no hope.
Revit 2018........
Title Block
Fri, Jul 27, 2007 at 2:02:38 PM
Font on Title sheet absent from project Title Block
Thu, Sep 15, 2022 at 12:31:26 PM
Title Block revision numbers
Tue, Feb 26, 2013 at 12:34:23 AM
Help Inserting Titleblock
Mon, Oct 21, 2013 at 3:39:31 PM
How to import my title block from AutoCAD?
Mon, Sep 10, 2007 at 4:25:43 PM
12
Page generation time: 0.4473
