Forums >> Revit Building >> Technical Support >> 3D component strangeness, green lines and not visible in 3d
Thu, Aug 7, 2014 at 4:00:01 PM | 3D component strangeness, green lines and not visible in 3d
Warchitect
4 Stars: 5 Votes
I have downloaded from Kohler this apron sink. My problem is that it does not show in any views (other than plan view), 3D or interior elevations. Can anyone tell me why?
-also, Why are the lines on it green? and how can I get it to be typical black lines. Can't seem to figure it on this model.
here is the part.
thanks in advance.
Fri, Aug 8, 2014 at 7:28:02 AM | 3D component strangeness, green lines and not visible in 3d
The green lines are a sub-category linetype (3d Fine) that these folks created.  They also created a 3D Coarse linetype that is blue.  You can change that color under your object styles settings.  These are all in the nested family.
This family type is not cuttable:  http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-3253EFCA-F38F-4086-9A4D-C873D8D04867
green model lines
Fri, Sep 9, 2016 at 11:36:06 AM
Green object lines
Mon, Sep 12, 2016 at 9:40:03 AM
Edit Cut Prolie Green Lines?
Sun, Apr 11, 2010 at 8:25:44 AM
component visibility in different plan views
Wed, Sep 19, 2007 at 10:44:53 AM
RAC2009 - > green lines in 3d view
Thu, Aug 21, 2008 at 11:12:33 AM
Page generation time: 0.9680
