13 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Typical Bathroom in Multiple Phase Project
6 Posts No Rating |
I've searched for an answer to this problem and haven't found anything. If this is a repeat, please accept my apologies.
Project: Hospital ward, built in 8 phases. Working drawings will be issued 1) as a full set for bidding, and 2) as a single phase for construction.
We want to note & detail one bathroom and reference it in 7 of the phases, so it would appear on 7 different sheets.
Is there a straightforward solution?
Thanks,
Julie
6 Posts No Rating |
Using Revit Architecture, 2014
I assume you are you asking about the callouts? .... or are you talking about using the same view on seven sheets?
Obviously you can duplicate a view with detailing as a dependent and place the duplicated views on multiple sheets. I would assume you can then use the reference other view to call those out but the phase of the callout may cause problems.
Please let us know when you test it out.
6 Posts No Rating |
It worked! I didn't think of this approach - I haven't spent a lot of time working with dependent views. There are no apparent problems with the phase difference.
Thanks for the help.
Want to have typical washroom elevation on multiple sheets |
Fri, Oct 23, 2015 at 11:20:00 AM
Drafting Views on Multiple Sheets-Revit 2008 |
Wed, Sep 3, 2008 at 3:11:48 PM
Changing phase for a large section of a project |
Mon, Nov 12, 2012 at 4:20:27 PM
Common Unit layout to different buildings / projects |
Wed, Aug 14, 2013 at 11:06:18 PM
Phase creating new beam |
Mon, Oct 26, 2009 at 2:22:06 PM
