Forums >> Revit Building >> Technical Support >> Demolish wall alyer
Fri, Aug 1, 2014 at 10:01:54 AM | Demolish wall alyer
camerongood210
Revit 2013
Is there a way to demolish wall layers, and not the wall itself? For example, we are adding on to a building that has exterior siding. The siding and plywood substrate would be replaced with gypsum board in this case. So, is there a way to show the siding/plywood only as being demo'ed?
Fri, Aug 1, 2014 at 10:29:13 AM | Demolish wall alyer
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I don't remember if 2013 has the Create Parts tool or not yet.  If it does you would need to select your wall and click Create Parts which will divide the wall into its individual structures (you cannot put it back once done however).  If 2013 does not have this you would need to create the siding/plywood as a seperate wall there is no way to only demolish a layer of the wall.
Fri, Aug 1, 2014 at 10:37:24 AM | Demolish wall alyer
camerongood210
Thanks for the response. Yeah, that's kind of what I thought. I tried the parts thing and it gave an error saying parts couldn't be created for some reason. This happened late last night, and I didn't spend much time investigating the problem. We'll give it another look, and hopefully get the parts error worked out. If not, we'll have to create the seperate walls like you mentioned.
demolish door with out infilling opening
Fri, Jun 5, 2015 at 9:30:39 AM
Clean up Demolish Wall...
Mon, Nov 8, 2010 at 7:52:01 PM
Demolish Tool
Thu, Sep 13, 2012 at 6:20:41 PM
Outline replaced wall when we demolish window
Fri, Mar 2, 2012 at 4:22:53 PM
demolish dormeropening
Thu, Mar 22, 2007 at 5:50:49 AM
Page generation time: 0.5662
