5 Users Online (3 Members):
Forums >> Revit Building >> Technical Support >> adding topography not to scale
28 Posts No Rating |
well basically when i add topography and select my file (from autoCAD which is at the correct size) and put it onto my project for some reason it seems to resize the topography and about 100times bigger than it should be, any1 know why?
extra info - btw i got the original file from the net as a dwf file and opened it in CAD. the scale was 1:1250 so i re-scaled the image to 1:1scale b4 putting it into revit, is this where ive gone wrong?
Post edited on 2006-03-04 13:30:43
what if you leave it the original size in acad and scale when you import?
35 Posts No Rating |
I have found that regardless of the issues you have now, that overall when Importing a DWG file into Revit-
In the Scaling section of the Import dialogue box select the DWG unit type it was drawn in specifically - DO NOT use Autodetect. If the original DWG file used millimetres to draw the toposurface import it using millimetres, this may solve your problems- it has certainly saved me a lot of grief.
Good luck!
----------------------------------- AutoCAD & Revit TAFE teacher from regional Australia |
Topography Scale |
Fri, Nov 25, 2011 at 3:27:35 AM
Rendering Elevation 3d views with scale |
Tue, Aug 14, 2012 at 9:43:43 AM
Issues with Topography |
Mon, Apr 18, 2005 at 1:22:56 AM
Topo coarse scale fill color |
Fri, Jun 15, 2007 at 10:00:13 AM
Adding Costum Scale to the default list? |
Tue, Jan 25, 2011 at 10:15:10 AM
