Forums >> Revit Building >> Technical Support >> Truncated cylinder?
Thu, Jul 31, 2014 at 7:00:36 PM | Truncated cylinder?
wbroner
wbroner Avatar
This ought to be easy to do in the Family environment.  I need to set a sloped plane whose location needs to be parametrically controlled, so that I can set the top of my cylinder to be sloped.  I'd want to control the angle of the slope and the height of where the sloping reference plan crosses the vertical axis of the cylinder.
None of the many searches I did point to a simple solution.
Some ideas and/or setp by step instructions will be appreciated.
Thank you.
Fri, Aug 1, 2014 at 7:32:08 AM | Truncated cylinder?
You can not control a reference plane in this manner but you can control a reference line.
Fri, Aug 1, 2014 at 7:04:47 PM | Truncated cylinder?
wbroner
wbroner Avatar
So if this can't be done with a reference plane, how is it to be done using a reference line?
Thank you all in advance.
having trouble creating a truncated cylinder
Wed, May 9, 2007 at 4:11:33 PM
truncated autocad dwg
Fri, Feb 24, 2012 at 11:20:27 AM
Cylinder with a angle
Wed, Jun 17, 2009 at 8:33:59 AM
Editing a family created by a company
Fri, Feb 14, 2014 at 9:07:20 AM
v.9 area analysis
Fri, Apr 21, 2006 at 2:41:26 PM
Page generation time: 1.6437
