14 Users Online (12 Members):
Forums >> General Discussion >> Revit Project Management >> Duct Tags
0 Posts No Rating |
I am using Revit 2014 and need help with a duct tag. I want the tag to include lining thickness or insulation thickness. But i only want the appropriate one to show. If the duct is insulated i dont want the lining portion of the tag to appear.
Edited on: Thu, Jul 31, 2014 at 1:56:47 PM
You might be able to set a conditional (y/n) parameter that evalustes the assigned thickness and turns a label on/off but that would only look right if the label was at the bottom of your data - not in the middle.
Maybe a better solution is two different type tags and the user uses the correct one.
Duct Tags - Airway |
Tue, Sep 6, 2011 at 9:04:46 PM
Help - Duct Callouts are relocating on drawing |
Fri, Mar 27, 2009 at 10:36:57 AM
Duct Fitting Issue |
Tue, Apr 1, 2014 at 1:16:35 PM
Duct won't tap to oval duct. |
Tue, Aug 22, 2017 at 12:38:49 AM
Eccentric Duct Fittings? |
Thu, Dec 15, 2011 at 10:58:31 AM
