Forums >> Revit Building >> Technical Support >> stair winder
Tue, Jul 29, 2014 at 10:09:27 PM | stair winder
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Hey guys whats the easiest way to create the stairs below. I read on some previous posts about winders but I am still unable to do it. Thanks in advanced.
I have just drawn in the winders in this case.
Revit 2018........
Wed, Jul 30, 2014 at 6:37:11 AM | stair winder
adgreen
You can use stair by sketch
-creat\stair\stair by sketch
-cleck riser/then draw one by one, you can use offset or copy
-the cleck boudary and draw it as shown in attachment (green)
hope this will help you
Wed, Jul 30, 2014 at 7:52:40 AM | stair winder
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
I tried and I get this error...
Can not finish sketch. Sketched path needs to pass through all riser lines, connecting the start and end riser lines.
Revit 2018........
Wed, Jul 30, 2014 at 9:44:51 AM | stair winder
adgreen
Check, my be there is risers overlapping each other, try to expand the boundary to cover all risers
Wed, Jul 30, 2014 at 6:20:28 PM | stair winder
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
I did it again and says same thing but had this. Tried few things but couldnt get it working.
Revit 2018........
Thu, Jul 31, 2014 at 1:57:36 AM | stair winder
adgreen
Try to it make in a new project revit file, and then copy it to your model
Thu, Jul 31, 2014 at 6:47:11 AM | stair winder
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
I didnt draw the stair path that was the problem thanks heaps for your help!
Revit 2018........
Winder Stairs in 2013
Tue, May 8, 2012 at 12:49:31 PM
How to achieve newell posts on winder stair
Tue, Jul 24, 2007 at 6:18:30 AM
partial wall miter below winder [ 1 2 ]
Sun, May 3, 2009 at 12:21:40 PM
20
Monolithic winder stair
Thu, Aug 22, 2013 at 12:50:18 PM
stair with 2 winder -> railing
Wed, Sep 9, 2009 at 12:38:00 PM
Page generation time: 0.8541
