Forums >> Revit Building >> Technical Support >> Shadows set using Geographic location relate to Project North not True North
Sat, Mar 4, 2006 at 2:15:27 AM | Shadows set using Geographic location relate to Project North not True North
Ultramarine
When I set shadows using Geographic location and date, time of day the azimuth and elevation are set correctly, but they are with respect to Project North (i.e. the top of the page is North) not True North. For example, if True North is set at 90 degrees to the East of Project North (i.e. the right side of the page) then I need to add 90 degrees to the azimuth for each shadow setting to get the shadows to show correctly for the specified time/date. Has anybody come accross a way to get around this, or should this be a "wish list" item?
SHADOWS ON SITE PLAN ORIENTED TO PROJECT NORTH AND NOT TRUE NORTH
Sun, Mar 9, 2008 at 11:08:24 PM
Project North doesn't rotate back after changed to True North
Fri, May 7, 2010 at 3:24:14 AM
True North vs Project North Linked dwgs
Thu, Mar 10, 2016 at 10:02:26 AM
How to Rotate True North without rotating the whole Project?
Thu, Mar 18, 2010 at 7:25:35 PM
True north help
Tue, Jul 21, 2015 at 3:52:04 PM
Page generation time: 4.2227
