Forums >> Revit Building >> Tips & Tricks >> RPC Creator
Mon, Jun 21, 2004 at 4:04:05 PM | RPC Creator
Mr GG
3.5 Stars: 9 Votes
To use your own photos of people, trees, cars.... in Revit you can use RPC Creator - it is freeware but you have to register first. Here is the adress: http://www.archvision.com/RPCCreator.cfm Here you can find .rfa-files to load into a component http://www.rugi.org/cgi-bin/peoplesexch.pl to experiment a little with... You must have an editable .rpc-file to start with to load into RPC Creator and you must have at least two images. One with the photo and one with the mask. You can make them in e.g. Photoshop. If you only have one image with a mask image you must in Step 4 in RPC Creator choose zero:s 0 for image and 0 for the mask - not 0000! You can use 360 images with 360 mask images if you like to and it will be a little more 3D -- but it is not necessary... Then you have exported the .rpc file with your own image from RPC Creator. You can open a .rfa file from the map Entourage in Revit and click Family Types to change the value of the parameter RPC Filename to your own .rpc-files name. And then save the .rfa-file with a new name. Now you can load the .rfa-file as a component in a Revit project and your image will get the right perspective proportions then you render a scen using the camera. Have a look in the Gallery on the image The Prammer Man to understand a little moore. I hope I get 50 more points for this tutorial??? Perhaps some day I will do it as a word-file and get my earning. Or everyone is free to make a tutorial from this explanation... so I do not have to do it myself. Just do it.
Rpc Creator archvison
Sun, Jan 22, 2012 at 10:20:41 PM
Rpc Creator made Rpc can't load
Wed, Oct 24, 2012 at 5:12:32 PM
RPC Creator Free Version - Download Link
Thu, Oct 25, 2012 at 9:08:32 AM
Free People for RPC Creator
Tue, Jan 3, 2006 at 6:55:55 AM
RPC creator free...What's the end?
Tue, Apr 16, 2024 at 3:53:11 PM
Page generation time: 1.2386
