Forums >> General Discussion >> Revit Project Management >> problem in 3D and elevation
Thu, Jul 24, 2014 at 3:40:44 PM | problem in 3D and elevation
kenyhel
when i go to 3d or elevation, the model is very small hard to find it, everytime i go to 3D, i need to zoom it first before i see it...
Thu, Jul 24, 2014 at 3:43:48 PM | problem in 3D and elevation
While it is very small, window the screen.  You will usually find something way off in space from your model.  Delete that.
Fri, Jul 25, 2014 at 8:22:43 AM | problem in 3D and elevation
kenyhel
how caan i find that?
Fri, Jul 25, 2014 at 8:26:52 AM | problem in 3D and elevation
As I said "....window the screen. "  This is a fundamental Revit tool.  Meaning use a pick window to select all the objects.  You should find some indicators far away from your model.  You can zoom in there and look at them.  Delete anything that is junk.
Tue, Jul 29, 2014 at 12:27:51 PM | problem in 3D and elevation
kenyhel
thank you so much...
over-riding elevation tags
Wed, Oct 1, 2008 at 3:37:15 PM
Change spot elevation dimensions 0.00 coordinate
Sat, Feb 4, 2012 at 10:56:05 AM
Elevation Tag - Leader Problem
Thu, May 17, 2012 at 5:48:20 PM
Spot elevation symbol [ 1 2 ]
Mon, Dec 1, 2008 at 10:10:59 AM
16
Elevation Callout loading, but can't be used
Wed, Jul 28, 2010 at 12:48:03 PM
Page generation time: 2.1326
