Forums >> Revit Building >> Technical Support >> Inclined curtain wall
Wed, Jul 23, 2014 at 6:20:03 AM | Inclined curtain wall
adgreen
Greeting , Want to ask, about the best way, To model inclined curtain wall, without using mass Thanks for all
Wed, Jul 23, 2014 at 7:34:59 AM | Inclined curtain wall
Either a mass - face based - or model in-place - modeling all elements (non-system).
Or you could build in a family.
Edited on: Wed, Jul 23, 2014 at 7:35:29 AM
Wed, Jul 23, 2014 at 7:39:36 AM | Inclined curtain wall
adgreen
Thanks, will try it....
Thu, Jul 24, 2014 at 6:50:04 AM | Inclined curtain wall
adgreen
I try it with roof by footprint, command added slop arrow , with hard slope Seems it is good, I can add my curtain grid and mullion On it.... Pls advise
Thu, Jul 24, 2014 at 7:14:28 AM | Inclined curtain wall
No.  You can create a sloping roof but you can't put curtain wall components on that.
Use the mass.
Mon, Jul 28, 2014 at 11:32:40 AM | Inclined curtain wall
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
Yes, you can start with a sloped roof by footprint and then add curtain panels and mullions. Simply change the roof type to be "sloped glazing" and then go to Edit Type and configure the properties of the mullions and panel.
Planta1 Revit Online Consulting | info@planta1.com
Mon, Jul 28, 2014 at 12:31:40 PM | Inclined curtain wall
Alf,
I'm glad you posted that.  As many times as I do a roof you would think I could remember that you have that type choice.
Thanks
Tue, Jul 29, 2014 at 11:37:55 AM | Inclined curtain wall
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
No problem. See? I am paying attention. Smile
Wed, Jul 30, 2014 at 12:52:14 AM | Inclined curtain wall
adgreen
yes it work, but as proffessional users, better to model it in a mass command
Wed, Jul 30, 2014 at 8:00:55 AM | Inclined curtain wall
I think the roof sloped glazing is far easier to modify than using the mass.
"...but as proffessional users, better to model it in a mass command..." << I don't understand this conclusion.
Is it a wall or is it a roof?  Although the system schedules as a roof, there is no associated area.  The mass created CW system is neither a roof or a wall and both "surfaces" are in the same schedule - again without area.  The panels and mullions all schedule under CW components for both mass created and roof created.
Wed, Jul 30, 2014 at 11:43:13 AM | Inclined curtain wall
#11
adgreen
Agree with you
Windows/opening/curtain system on inclined wall
Tue, Apr 21, 2009 at 5:16:45 AM
editing an inclined wall
Tue, Apr 26, 2011 at 4:05:45 AM
adding a parameter in an inclined wall family
Mon, Dec 29, 2008 at 5:29:48 PM
Curtain wall assigned to inclining surface of SweptBlend​?
Thu, Dec 13, 2012 at 4:17:33 PM
concrete beam on top of inclined wall
Wed, Jun 20, 2007 at 11:09:17 AM
Page generation time: 0.7991
