Forums >> Revit Building >> Technical Support >> Column Shadow Display Problem
Tue, Jul 22, 2014 at 5:20:49 AM | Column Shadow Display Problem
krlfschr
Hi RC
I don't know if I'm missing a simple setting, or whether there's some thing bigger that is wrong with my model.I cannot get my columns to cast shadows correctly in plan; but they work in 3D.
All columns have identical base heights/settings as the adjacent brickwork, which is obviously working properly.
I've checked my view range & everything looks normal. I also have no plan regions.
Has anybody encountered this before?
Thanks.k
133001_Column_Display_Problem.JPG133001_Column_Display_Problem3D.JPG133001_Column_Display_Problem3D2.JPG
Tue, Jul 22, 2014 at 7:00:06 AM | Column Shadow Display Problem
Send this to Autodesk.
Wed, Oct 24, 2018 at 10:20:20 AM | Column Shadow Display Problem
PropelStudio
PropelStudio Avatar
Hi krlfschr - Did you ever figure this out? We are experiencing it too. Can't seem to figure out why... Thanks!
Propel Studio is a community oriented architecture, design, and development studio located in Portland, Oregon.  www.propelstudio.com
Thu, Oct 25, 2018 at 1:32:55 AM | Column Shadow Display Problem
tim123
4 Stars: 19 Votes
The settings in the attached image reproduce the condition.  Could it be this?
Mon, Nov 4, 2019 at 6:25:26 AM | Column Shadow Display Problem
Steve19857
Hi Guys,
We found the solotion, it is to set the cut plane of the ref level in your column family higher than you cut plane within your project.
hope this helps
Doors make a gray shadow in Sections
Wed, Apr 7, 2004 at 10:39:43 AM
DISPLAY COLUMN LABELS
Wed, Sep 8, 2010 at 3:53:41 AM
Shadow Casting
Thu, Feb 12, 2009 at 10:00:48 PM
shadow projection on walls
Thu, Apr 14, 2011 at 2:29:41 AM
Graphical Column Schedules problem....
Wed, Sep 9, 2015 at 12:41:56 PM
Page generation time: 1.8714
