25 Users Online (23 Members):
Forums >> Revit Systems >> Technical Support >> Rooms in linked Revit model
0 Posts No Rating |
We are using Revit 2014 and I have linked the architectural model into the MEP model. However the rooms from the architectural model is not showing up in the MEP therefore i can't tag the rooms. Please help
Thanks,
See this post http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-76F60AC2-35AE-4FE8-8FA2-A7544EB7E75A and similar threads below.
0 Posts No Rating |
I have tried that. In Revit 2013 I was able to tag rooms from a linked revit model. The tags would read the information from the architectural model and i don't have to remake all the rooms. However, in 2014 it looks like the rooms from the architectural model wasn't "linked" into the MEP model.
Thanks teafoe5.
What you could do is go into the linked file, and see if the rooms are already tagged, ebcause if they are, you could just go into your visibilty graphics in YOUR project and go to revit links tab>select the last collumn for that link that says "By Host View">in the fist window select the custom bubble>then go to the annotation tab>the very first selection you see says "by host view" again, drop that down, and select custom> then everything should ungrey>scroll down to room tags and turn them on.
if the rooms aren't tagged and you know the rooms are already created, you could just tag them in the link file, reload, in your manage links window, and repeate the steps aboveif they still do not show.
0 Posts No Rating |
Thank you teafoe5 and Pikachu123 for the reply.
I've found the solution to my problem. The phases of the architectural model was not matching the phases of the MEP model. Once i have matched the phases in the "Phase Mapping" the rooms showed up.
bl
Rooms not displaying from linked architectural model - Revit 2018 |
Thu, Jan 17, 2019 at 2:41:26 PM
Not able to place room copied from linked model |
Wed, Mar 18, 2015 at 8:10:37 AM
Rooms and Spaces from linked model (Revit MEP 2011) |
Sun, Jul 18, 2010 at 9:40:06 AM
Help Please with Scheduling Rooms from Linked Revit Model |
Mon, Aug 8, 2011 at 1:10:25 PM
2019 scheduling rooms from linked model using level from main model |
Wed, Dec 11, 2019 at 2:55:46 PM
