13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Voids 2
Perhaps someone can explain yet another strange occurance with voids. So im modelling in place within my project. I have created an extrusion and i have decided to add multiple void sweeps to it in order to give it different ornamental profiles. So in typical fashion I created a reference plane, set the reference plane, then applied the void sweep, everything works perfectly. Now I create another void sweep, EXACTLY the same shape, using EXACTLY the same profile and I set EXACTLY the same reference plane. Every setting is precisely the same yet this one doesn't cut... Very frustrating.. Makes no sense.
If everything is exactly the same then what are you cutting with the second one? The first one would already be cutting it. An inage is always helpful.
We would have to see the exact process.
You are editing your in-place and adding this new void - correct? ...not trying to cut it afterwards.
Wall by face on curved solid - VOIDS not seen |
Mon, Jul 29, 2013 at 1:29:54 PM
A Problem with Voids |
Fri, May 18, 2012 at 8:41:19 AM
Cutting with Voids outside of families |
Wed, May 23, 2012 at 7:53:29 AM
Voids in Array cuts all elements, instead of only some |
Tue, Jan 22, 2019 at 4:09:02 PM
How do I make voids disappear in a family with a yes/no visible parameter? |
Fri, Oct 27, 2006 at 1:05:08 PM
