11 Users Online (9 Members):
Forums >> Revit Building >> Tips & Tricks >> Revit door families
I have a few door openings in my rounded silo wall, that were created by families. I need to be able to tag them in plan view to show both the mark # and the top and bottom elevations of the actual openings. i am able to tag the door opening itself with a mark number. When i choose an elevation marker and choose top and bottom elevations, and pick the door opening, it selects the top and bottom elevations of the wall instead. Does anyone have a work around for getting the elevations to select the opening itself instead? Or even better woudl be a door tag that includeds the top and bottom opening elevations within? Any helpful hints would be greatly appreciatd.
"When i choose an elevation marker" Are you talking about a spot elevation?
In your door tag you can add a mark for head height and sill height to the tag
That seemed to work, but i have a base elevation of 100'-9" that i need to account for. Any way to get those elevations to read a true project elevation instead of relative?
yes, a spot elevation marker is what i was referring to
I'm not sure what you mean, it's reading 100'-9", what do you want it to read?
The door family acknowledges the sill height variables, but it does not convert them into a target project elevation. It recognizes the opening for the door as elevation 0, when it should be reading elevation 100'-9", which is my project elevation accorduing to the levels i have created.
Door sill and head is only relative to the level - never to the project so you should account for that ... maybe changing your spot elevation to RELATIVE and adding AFF as a suffix.
Door Families and Profiles |
Thu, Apr 22, 2010 at 1:06:47 PM
Door family - opening covers door leaf |
Fri, Sep 30, 2016 at 4:36:46 AM
Door swings with nested families |
Fri, Sep 18, 2009 at 1:41:24 PM
Control Position of Door Frame/Panel in Wall Thicker Than Door Frame |
Thu, May 6, 2010 at 7:29:41 AM
Controlling visibility of nested families in familes with multiple types |
Mon, Jan 6, 2014 at 10:37:45 PM
