Forums >> Revit Building >> Technical Support >> Revit materials
Thu, Jul 17, 2014 at 3:54:06 PM | Revit materials
mfurlong
When exporting a Revit model to Navisworks, all textures and materials reside within that model file.  In Navisworks, I alter the transparancy of walls and ceilings using an appearance profile file.  With the testure (a png) attached to the wall and ceiling elements, the transparancy and color alterations is null and only the bitmap shows.
How can I remove (globally, if possile) all the bitmap tetures in Revit, without disturbing the wall "type" to allow the transparancy to be changed in Navis?
Thanks,
Mike Furlong
Integrated Project Solutions.
Adding materials into Revit's materials files
Thu, Jul 22, 2010 at 1:54:48 PM
Converting DWG materials to Revit Materials
Thu, Sep 13, 2012 at 3:50:29 AM
Revit Custom Materials Rendering Objects invisble
Mon, Mar 14, 2011 at 10:42:55 AM
13
REVIT 2009 - MATERIALS
Tue, May 5, 2009 at 10:01:40 AM
12
When editing materials through properties, only two show up??
Tue, Mar 13, 2012 at 3:38:21 PM
Page generation time: 1.3183
