24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Material library
We have an extensive material library at work & I need to copy that and put it on my home computer. How do I add this to the existing library.
Thanks for any help
Macca Sunshine Coast QLD Australia |
20 Posts No Rating |
Puzzle,
Are you referring to just the .MLIB or to the Maps or both? It is my understanding that you don't need to add these directly to your library, unless you really want to. As an option, you can easily add the pathway to your maps and your MLIB in SETTINGS > OPTIONS > RENDERING.
The definitions in the Materials Dialogue have a 'base' amount of materials, to which you can add or modify defintions. (These are project specific, but you could add/modify the definitions in your Template.) Once your MLIBS are pathed, you'll still need to create a definition for your material to be used, then define it under the Accurender Texture material.
When you go to the Accurender Texture, you should see your MLIBS show up in the folder tree on the left side.
Hope this helps,
Kyle
Question about shared custom material library |
Wed, May 18, 2016 at 6:44:31 AM
How do you add an imported material to Revit's material library ? |
Mon, Aug 16, 2010 at 8:06:17 AM
Material Photo's Library |
Tue, Dec 8, 2009 at 3:19:26 PM
Help me! Lack of BMCD2AR3 material library in revit building 8. |
Sat, Oct 8, 2005 at 9:54:16 PM
Material Library with custom parameters. |
Fri, May 6, 2016 at 3:36:29 PM
