Forums >> Revit Building >> Technical Support >> lines styles not printing or displaying
Thu, Jul 17, 2014 at 8:36:08 AM | lines styles not printing or displaying
grebnesor
So I'm playing around with line styles in Revit 2014 but I can't seem to get anything but the default styles to display. I'm simply trying to get shafts to appear as dashed instead of solid and I've changed both the object styles and the graphic overrides to a dashed line but still nothing. Oddly enough, when I select the object, the lines are highlighted in whatever pattern I choose, but the typical display refuses to change. Any ideas as to how to fix this? Thanks
Thu, Jul 17, 2014 at 8:50:30 AM | lines styles not printing or displaying
Are you sure you want the shaft or do you really want the opening?
Shafts are really a void cut and are invisible unless you roll over them.  The opening cut by the slab is really just the floor and defined by the line assigned to that.  If you want the opening dashed then you will have to use the linework tool.  (I don't know why you would want an opening dashed.)
Removing Line Styles
Mon, May 8, 2017 at 2:21:04 PM
Black lines printing grayscale in PDF
Fri, Oct 10, 2014 at 4:46:46 PM
Lines Greyed-out, but Annotations Not When Printing with CutePDF
Thu, Dec 6, 2012 at 7:52:16 AM
Line Styles Adjusting with Wall Hidden Lines?
Mon, Mar 12, 2018 at 12:58:29 PM
missing lines when printing
Fri, Jul 20, 2012 at 12:17:59 PM
Page generation time: 0.3297
