Forums >> Revit Building >> Technical Support >> Resizeable array components
Wed, Jul 16, 2014 at 5:07:30 PM | Resizeable array components
KasperWuyts
Good day everyone,
I have a family editor question (I am relatively new to family editing and am using Revit 2014):
If you have a component in an array, is it possible to resize the component using parameters? Intuitively it appears to me like there should be no problem trying to do this, yet Revit keeps giving me constraints-not-satisfied-errors.
Included is a very simple example of what i mean: A box that has a width and heigth dimension and is part of an array. Trying to adjust the dimensions of the box leads to errors.
Wed, Jul 16, 2014 at 8:40:59 PM | Resizeable array components
ronmalit
5 Stars: 3 Votes
hi
revised your file, kindly check it
Thu, Jul 17, 2014 at 2:43:46 PM | Resizeable array components
KasperWuyts
So the trick was to use a nested family as an array object. I guess I should have tried that. Thank you very much.
As a result of this I was able to create my first parametric line based family. It's a detail family for a section view of a membrane, one of the things I miss most since switching from Vectorworks to Revit. It's not perfect, but still, proud of the work. Smile
Many regards and thanks again
Kasper Wuyts
how can I array along spline? [ 1 2 ]
Fri, Nov 28, 2008 at 7:07:32 AM
19
Array along a curved path
Tue, Nov 11, 2014 at 9:11:45 AM
2-dimensional Array of Arrays
Wed, Aug 3, 2011 at 7:47:12 AM
Parametric Array Constraints
Tue, Jul 2, 2019 at 7:00:45 AM
Array association
Tue, Nov 11, 2008 at 9:17:31 AM
Page generation time: 0.4856
