17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> help! cannot load new column family into project
0 Posts No Rating |
Hello!
I am trying to load a column that I created into a Revit floor plan and it says that it cannot be loaded. I attached it and if anyone can figure out what I did wrong that would be amazing!
You have it as an air terminal family, you need to change it to be a column, once I did that I had no problem.
0 Posts No Rating |
How did you change it to a column? I tried to copy and paste it into a new column family and it still did not load
You should read the Families Guide it will be a huge help on learning families
http://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Autodesk-Revit-Architecture-Families-Guide.html
You need to open the family that you have and on the Create tab>Properties panel> Family Category and Parameters> In the Family Category and Parameters dialog box change it to Columns and hit ok then click load into project.
0 Posts No Rating |
I did that, but then I got an error message saying "some or all of the family files you selected cannot be loaded. You must choose family files of the category component." Is there another step I forgot to do?
family dont Load!! |
Sat, Apr 18, 2015 at 9:22:41 AM
WT column - help? |
Fri, Jun 14, 2013 at 9:10:49 AM
Not able to import families through load family..no error msg.jury tomo!! |
Thu, Jun 6, 2013 at 9:24:12 PM
Family Will Not Load |
Tue, Apr 12, 2011 at 7:36:56 PM
Unable to Load Family into Project |
Thu, Mar 19, 2009 at 6:46:18 PM
