Forums >> Revit Building >> Technical Support >> Far Clipping Stops working when I zoom in/ out of view
Tue, Jul 15, 2014 at 4:44:06 PM | Far Clipping Stops working when I zoom in/ out of view
Rbec
I have far clipping set up in an elevation view. If I zoom in or out in the view, the far clipping stops working throughout the project- I can see the full view depth in the elevation, and in plan I can't adjust the clip depth. If I switch the clip to "reset" from clip with to without line, the view is clipped (in plan and elevation)- but the second I zoom, it all resets again. Does anyone have any experience with this delightful bug? I'm in Revit LT 2015.
Wed, Jul 16, 2014 at 7:35:28 AM | Far Clipping Stops working when I zoom in/ out of view
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I don't have LT but is it up to date with all of the service packs?
Wed, Jul 16, 2014 at 8:39:20 AM | Far Clipping Stops working when I zoom in/ out of view
This may be a video card issue.
Wed, Jul 16, 2014 at 9:30:35 AM | Far Clipping Stops working when I zoom in/ out of view
Rbec
All my security packs are up to date (the only one out for 2015 LT is a security patch for heartbleed). I should have mentioned that it's only exhibiting this behavior in one view, so I don't think it's a video card issue- particularly since the clipping is also turned off in the plan view when it turns itself off in the elevation view, which suggests to me that the clip/ no clip property of the view is what's causing the problem.
I'll probably wind up re-creating the view, but I thought I'd check to see if anyone else had had similar issues, i.e. if this is something I can expect to have to deal with intermittently. Looks like it's just me Puh
Wed, Jul 16, 2014 at 9:39:33 AM | Far Clipping Stops working when I zoom in/ out of view
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You could try it on a different computer and see if you are getting the same results
Wed, Jul 16, 2014 at 9:47:58 AM | Far Clipping Stops working when I zoom in/ out of view
TGhere are 3 updates for 2015
http://knowledge.autodesk.com/support/revit-lt/downloads/caas/downloads/content/autodesk-revit-lt-2015-update-release-3.html
Wed, Jul 16, 2014 at 10:14:01 AM | Far Clipping Stops working when I zoom in/ out of view
Rbec
I'm on the latest build- 20140323_1530- so I don't think that's the issue.
Wed, Jul 16, 2014 at 10:27:26 AM | Far Clipping Stops working when I zoom in/ out of view
The build has nothing to do with the updates!!!!
Wed, Jul 16, 2014 at 10:38:15 AM | Far Clipping Stops working when I zoom in/ out of view
Rbec
Sorry for the duplicate post- but, to quote the Revit Update site "After Update Release 3 is applied successfully, the build number specified on the Help > About dialog will be 20140606_1530."
So, as I read it, the build does have something to do with the updates- and I missed update three on the page due to the layout of the webpage. I'll try installing release three and seeing if it helps.
Wed, Jul 16, 2014 at 11:12:49 AM | Far Clipping Stops working when I zoom in/ out of view
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You build number should have what update it is, as WWHub said, the build number doesn't matter its your update number.
Wed, Jul 16, 2014 at 11:13:22 AM | Far Clipping Stops working when I zoom in/ out of view
You are correct.
Typically, Revit's updates are only patches and must be installed in order.   I see that this one includes the previous patch.
Sorry about my mistake.
Wed, Jul 16, 2014 at 11:20:39 AM | Far Clipping Stops working when I zoom in/ out of view
Rbec
Looks like update 3 fixed the issue, in case anyone else out there in the internet is having similar issues. I'm going to have to get used to managing my own updates again...
Zoom and text - any way to tell which zoom level you are working in?
Wed, Jan 7, 2015 at 9:30:59 AM
Clipping Callout Bubbles when clipping View
Thu, Jan 3, 2013 at 6:24:11 AM
RAC2009 - Kwyboard stops working after using Pantone colors
Tue, Jul 15, 2008 at 1:32:21 PM
13
Undo/Redo command stops working
Fri, Apr 30, 2010 at 10:33:35 AM
IMPORTED DWGs - Clipping?
Fri, Jul 11, 2008 at 10:42:32 AM
Page generation time: 3.7759
