Forums >> Revit Building >> Technical Support >> Top rail offset
Mon, Jul 14, 2014 at 2:10:03 PM | Top rail offset
Warchitect
4 Stars: 5 Votes
My top rail was nicely centered on my railings but I needed to move over the baluster...and so I have adjusted my baluster to center it up, but the top rail moved over in response to that. I can't seem to find the place to adjust the top rail sideways to also bring it back in line with my railings and baluster.
anyone know where that is?
Tue, Jul 15, 2014 at 2:37:37 AM | Top rail offset
ronmalit
5 Stars: 3 Votes
hi
hope this will help u
if you really must, you can:
edit/open the TOP RAIL profile family
add an offset parameter. then you can adjust the offset value by editing the type property
Edited on: Tue, Jul 15, 2014 at 2:38:22 AM
Edited on: Tue, Jul 15, 2014 at 2:38:44 AM
Tue, Jul 15, 2014 at 5:50:23 AM | Top rail offset
4 Stars: 205 Votes
You have that "Offset" parameter when you edit rails
Tue, Jul 15, 2014 at 7:06:33 PM | Top rail offset
Warchitect
4 Stars: 5 Votes
No you dont typhoon. the top rail is not in the list of railings to be offset, it is its own thing now. I think the above post is the only way to do it now.
also, how did you draw a railing that has no "top rail"
Edited on: Tue, Jul 15, 2014 at 7:07:06 PM
Edited on: Tue, Jul 15, 2014 at 7:10:20 PM
Wed, Jul 16, 2014 at 8:11:17 AM | Top rail offset
Warchitect,
You can still use the guard only railings where the top rail is not skecthed seperately.  Isn't that what you should be using here?
Wed, Jul 16, 2014 at 12:10:42 PM | Top rail offset
Warchitect
4 Stars: 5 Votes
Ah. didnt realize that I could choose "none" as a top rail. OK. but once I do that, this warning comes up and kills my balusters. :-(
can you tell me why? What top reference are they referring to that affects the balusters?
Edited on: Wed, Jul 16, 2014 at 12:14:32 PM
Edited on: Wed, Jul 16, 2014 at 12:15:03 PM
Wed, Jul 16, 2014 at 12:15:44 PM | Top rail offset
Check the top and bottom references for your ballusters.... I think that since you are deleting the handrail, you will need a new top rail.
Wed, Jun 21, 2017 at 10:17:15 AM | Top rail offset
sllana
5 Stars: 2 Votes
Guys, a little late, but just in case: what you have to do in that situation is not to use top rail but "handrail 1 or 2" that have offset parameter and of course set the balusters to top to that rail. Handrails 1 and 2 are different families so you must have them configured. And if you want to move the balusters along the handrail, configure them as "supports" not as balusters, and include them in the handrail parameters.
Wed, Jun 21, 2017 at 11:14:51 AM | Top rail offset
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
@Warchitect fyi, top rail lateral offset parameter it’s called Hand Clearance.
Baluster Top Offset Issue
Tue, Jan 12, 2016 at 8:43:40 AM
2015 use baluster per tread on stair (with no top rail?)
Thu, Sep 3, 2015 at 4:50:57 PM
Rail Top Rail vs Handrail 1
Tue, Nov 26, 2013 at 9:58:49 AM
How do I change the top rail profile in Revit 2015?
Thu, Sep 28, 2017 at 7:54:29 AM
Stair Rail extending through Balister
Tue, Nov 20, 2007 at 3:59:06 PM
Page generation time: 0.4398
