Forums >> Revit Building >> Technical Support >> Revit Topography schedule - several issues!
Sat, Jul 12, 2014 at 8:49:59 AM | Revit Topography schedule - several issues!
sekins
Hi all
I am using Revit 2014. I created a topography, created in existing, demolished in new construction. I also added a subregion to this. I then "graded" my topo by copying the topo with same internal points etc, phased it to created in new construction, and then proceeded to grade it as necessary.
I then changed boundary lines of the subregion on the new topo as the paved areas will overlap. Ie some paving will be lifted and reused, in addition to new paving bricks.
I have also added 2 pads in new construction phase.
I created a topography schedule to calculate the cut and fill for my site. my problems are as follows:
1. I want the total of cut and fill and net cut/fill for old vs new. I really dont want to know each of the cut and fill values for my subregions. How do I manipulate my schedule to do this?
2. My existing topography shows cut and fill values. Pretty significant values. How is this possible? Surely it should be 0?
3. My pads (or I should say the topography under my pads) do not calulate any cut and fill at all. All the values display as 0.
4. I tried to add another subregion to my existing topo and it will not let me make is existing at all!!! No matter what I do.
Please help, I am at my wits end. I have never been so frustrated by revit.
Sun, Jul 13, 2014 at 1:18:40 PM | Revit Topography schedule - several issues!
PedjaCh
I think that problem is in "... I created a topography, created in existing, demolished in new construction..."
Do not demolish existing topography
Mon, Jul 14, 2014 at 8:59:00 AM | Revit Topography schedule - several issues!
Did you read this in your HELP?
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-F9994BBC-027A-41B8-8852-FB33A34C3AC7
Topography Issues
Fri, May 18, 2007 at 9:38:48 AM
Issues with Topography
Mon, Apr 18, 2005 at 1:22:56 AM
Topography Cut/Fill Schedule
Thu, Nov 16, 2006 at 11:15:51 AM
Graphical column schedule issues (Revit Structure)
Thu, Apr 24, 2014 at 3:24:33 PM
Topography - Cut and Fill for Graded Region
Fri, Feb 4, 2011 at 11:31:15 AM
Page generation time: 3.8071
