Forums >> Revit Building >> Technical Support >> REVISION TAG AND SCHEDULE
Wed, Jul 9, 2014 at 7:03:47 PM | REVISION TAG AND SCHEDULE
qayyumaqashah
HI.
I'm the Revit 2014 user.
was having dificulties on working with revision.I did the revision cloud and tagged it . so my problem is:
1. the tag no appeared when 'per-project' is checked in the sheet issues/revision field but it was otherwise if 'per-sheet' is checked. What is the different between these two?
2.athe revision information is inserted but does not show in the schedule.
3.revision on sheet: there is no check box in the column of 'show in revision schedule'
do i missed out some  step here?
very much appreciate your help. thank you
132705_REVISION_DESCRIPTION_NOT_SHOW_IN_THE_SCHEDULE.JPG132705_REVISION_ON_SHEET_-_NO_CHECK_BOX_APPEARED.JPG132705_REVISION_SCHEDULE.JPG132705_SHEET_ISSUES-REVISIONS.JPG
Wed, Jul 9, 2014 at 11:01:47 PM | REVISION TAG AND SCHEDULE
ronmalit
5 Stars: 3 Votes
hi
depends on how u created your (sheet) title block and how u customize the fields of your revision schedule.
i suggest u add all the fields, and hide the unnecessary field.
1.a. per project: revit will show the REVISION SEQUENCE in the sheet. but numbers/letters will be skipped (1,3,6)
1.b. per sheet: revit will automatically adjust the revision numbers/letters so it will be in sequence (1,2,3)
2. something is wrong in there... even a newly created project (empty) has a default Revision 1. and a newly inserted sheet will show Revion 1 in the "revisions on sheet" panel.
Thu, Jul 10, 2014 at 7:43:12 AM | REVISION TAG AND SCHEDULE
The revision schedule has to be part of the sheet family - created in the family editor.
Sun, Jul 20, 2014 at 3:09:52 AM | REVISION TAG AND SCHEDULE
qayyumaqashah
hi,
sorry for the late respond. very help full explaination. thank you very much for the help. appreciate it.
To set up Revision cloud schedule, and add prefix to Revision Number?
Sun, Jul 19, 2020 at 6:35:17 PM
Hiding a Revision in the Revision Schedule
Thu, Nov 21, 2013 at 3:04:51 PM
Revision Schedule not updating
Tue, Aug 28, 2012 at 7:59:18 AM
View >> New >> Revision Schedule (GONE!)
Tue, Feb 20, 2007 at 11:48:28 AM
REVISION SCHEDULE
Mon, Nov 10, 2008 at 2:18:55 PM
Page generation time: 0.5915
