Forums >> Revit Building >> Technical Support >> a different Render problem
Thu, Mar 2, 2006 at 3:21:34 PM | a different Render problem
db
anyone experienced a Revit file that,, each time you open it,, will render fine once... then shut down when a second one is started? Therefore, i cannot run a walk through i need to. It's just this file i'm experiencing this with so far. Post edited on 2006-03-02 15:22:55
Thu, Mar 2, 2006 at 7:11:28 PM | RE: a different Render problem
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You'll need to send the file to support most likely. You could try opening the file with the audit button checked? Also make sure you are using the latest build..
Fri, Mar 3, 2006 at 9:24:57 AM | RE: a different Render problem
K-Pax
This is a known problem to a lot of people, although the fix is unkown. Typically it appears to come from updating an older file into a newer version, specifically the earlier 8.1 builds. Spot is right on to see that you've got the latest build (January's, I think) which does help. I've also heard suggestions to the effect of deleting the camera view and rebuilding it. If you're using 8.1 also do an Audit on the file (Under File >Open> (lower right corner) to see if there is any bad Geometry. Good Luck - sorry this isn't that specific. Kyle K-Pax
Render problem
Thu, May 30, 2013 at 12:37:29 AM
Render in Cloud Problem
Fri, May 24, 2013 at 8:19:23 AM
Render problem in 2009 with existing phase
Thu, Aug 28, 2008 at 2:55:45 PM
New Render Appearance
Tue, Jul 6, 2010 at 9:45:22 AM
Wooden floor render problem - how to change direction of flooring???????
Fri, Mar 18, 2011 at 2:42:49 PM
Page generation time: 3.1284
