Forums >> Revit Building >> Technical Support >> PLEASE HELP! ROTATING AN ELEMENT ON A RAMP (Revit 2014)
Wed, Jul 9, 2014 at 12:56:28 PM | PLEASE HELP! ROTATING AN ELEMENT ON A RAMP (Revit 2014)
doogster19
I am trying to rotate a truck on a long truck ramp, and can't get the truck to align with the ramp so it looks like it's actually on the ramp. It won't let me pick a workplane or rotate the truck when I edit it in the family. If anybody knows how to solve this please tell!! Thanks!
Wed, Jul 9, 2014 at 1:09:47 PM | PLEASE HELP! ROTATING AN ELEMENT ON A RAMP (Revit 2014)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
We don't know anything about the family or how it was built so we can only guess.  When you pick on the truck do you get an option to select a new host?
Wed, Jul 9, 2014 at 1:22:54 PM | PLEASE HELP! ROTATING AN ELEMENT ON A RAMP (Revit 2014)
Can you rotate the family in elevation at all?  If not, open the family, in the upper left corner / properties tab, click on the icon that has the yellow file folder and uncheck "Always vertical" - then reload the family.
Wed, Jul 9, 2014 at 1:30:04 PM | PLEASE HELP! ROTATING AN ELEMENT ON A RAMP (Revit 2014)
doogster19
Here is the tuck I am using:
http://www.revitcity.com/downloads.php?action=view&object_id=5164
And yes it shows the pick new host button but doesn't actually allow me to pick a new host.
Wed, Jul 9, 2014 at 1:31:31 PM | PLEASE HELP! ROTATING AN ELEMENT ON A RAMP (Revit 2014)
doogster19
Also, the "Always Vertical" thing didn't work..
Edited on: Wed, Jul 9, 2014 at 1:33:34 PM
Wed, Jul 9, 2014 at 1:41:42 PM | PLEASE HELP! ROTATING AN ELEMENT ON A RAMP (Revit 2014)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
In the family uncheck always vertical and check workplane based.  You can then either use Edit Work Plane or use the Pick New option in the project
Wed, Jul 9, 2014 at 1:50:22 PM | PLEASE HELP! ROTATING AN ELEMENT ON A RAMP (Revit 2014)
Your family set to work plane based / always vertical unchecked and placed on a ramp in a project.
Wed, Jul 9, 2014 at 2:43:28 PM | PLEASE HELP! ROTATING AN ELEMENT ON A RAMP (Revit 2014)
doogster19
It works!
Thanks!
Ramp and Topo surface problem Revit 2014
Thu, Oct 9, 2014 at 8:36:16 PM
A ramp!
Thu, Jan 21, 2016 at 11:37:45 AM
Revit 2014 - 3D Views are Fast!
Tue, Apr 23, 2013 at 7:56:57 AM
RAMP TAG FAMILY FOR RAMP NAME
Mon, May 9, 2016 at 6:49:09 AM
Wall attached to Ramp
Fri, Apr 19, 2013 at 1:19:57 AM
Page generation time: 2.8905
