Forums >> Revit Building >> Technical Support >> LINK FILES
Wed, Jul 9, 2014 at 4:30:25 AM | LINK FILES
LOSpistos
Hellooooooooooooooooooooooooooooooooooo,
so my question is if its possible to assign project parameter (base level parameter) to linked files to be able to adjust for instance the base level distance. Im having 15 unit types (all of them are linked) inside my main model and im just looking the best way how to be able to manage the contraints from the level 00.
Maaaaaany thanks
Luba
Wed, Jul 9, 2014 at 7:18:47 AM | LINK FILES
You will have to manually move the link to the correct location.
If you have only one instance of each type (you should have said) then your best method is to use shared coordinates.
Manage Link - Reload From MULTIPLE FILES !
Wed, Dec 9, 2009 at 12:55:03 PM
Site plans and Linking with Master files
Fri, Jul 7, 2006 at 6:55:40 PM
Link Revit File
Tue, Dec 4, 2018 at 11:59:19 PM
Newbie - How to Link consultant's revit files? what to use for position?
Thu, Jul 23, 2009 at 5:43:47 PM
Linking Revit files
Fri, Jul 22, 2005 at 6:08:10 PM
Page generation time: 8.0035
