Forums >> Revit Building >> Technical Support >> Interior Elevation Option is not available
Tue, Jul 8, 2014 at 1:50:36 PM | Interior Elevation Option is not available
Balitog
Using Revit 2013
The only option to create an interior view is to use the Building Elevation family which has the wrong graphics. The option is not available in the properties drop down menu and therefore I cannot change the type.
Any suggestion would be greatly appreciated
Than you very much
Christian Fekete Architect
Tue, Jul 8, 2014 at 2:07:23 PM | Interior Elevation Option is not available
First - do you have all 3 updates installed for 2013?
Someone must have deleted it the type you want so simply create a new type.  DUPLICATE!
Tue, Jul 8, 2014 at 2:15:39 PM | Interior Elevation Option is not available
Balitog
I found the solution, I created an interior elevation view type then, changed the elevation tag to a circled 1/2" and revit handled the rest, it works.
Thank you very much for responding
Best
CF
Interior Elevation not visible in drop down
Thu, Feb 6, 2014 at 9:19:32 AM
Interior Elevation Tags
Mon, Jul 21, 2025 at 11:28:06 AM
Revit 2011 Multiple Interior Elevation References
Wed, Oct 26, 2011 at 9:01:48 AM
Interior Elevation Tag missing from drop down
Wed, Aug 18, 2010 at 4:28:45 AM
Using Visibility Graphics to control elevation callouts
Wed, Nov 12, 2008 at 9:58:42 AM
Page generation time: 0.4180
