Forums >> Workflow & Implementation >> API & Third Party Apps >> How to highlight an element while the command is running
Mon, Jul 7, 2014 at 1:10:52 PM | How to highlight an element while the command is running
kukuzry
My plugin will show a Window Form with different room properties listed on it. What I want is to highlight anroom when I select this room from GUI. Is there any simple way to do it?
The method mentioned in this blog (http://thebuildingcoder.typepad.com/blog/2010/06/highlight-elements.html) can highlight an element only after the Execute() function is finished. However, I want the element to be highlighted in between (i.e., Window Form GUI is still running and a room can be hilghlighted by selecting this room from this GUI)
Thanks,
Mon, Jul 7, 2014 at 2:04:10 PM | How to highlight an element while the command is running
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What plugin?
Mon, Jul 7, 2014 at 2:32:25 PM | How to highlight an element while the command is running
kukuzry
I developed a plugin to show room info in the Window Form.
highlight while hovering
Mon, Jan 23, 2006 at 10:47:18 PM
Mass import highlight
Thu, Mar 25, 2010 at 3:52:05 PM
Dimensions will not highlight when i select an object
Thu, Jan 5, 2012 at 3:02:15 PM
Obscuring building to highlight main building
Mon, Jun 13, 2011 at 8:55:56 PM
family element render materials [ 1 2 ]
Sat, Feb 14, 2009 at 10:47:01 AM
17
Page generation time: 1.7857
