25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Turning 'Ortho' Off
3 Posts No Rating |
Is it possible to turn off the snap to horizontal or vertical when trying to draw lines at shallow angles like 1/8" per foot?
Snap Off (SO)
3 Posts No Rating |
Thanks...so obvious.
FYI,
Another way to temporarily turn off the "Ortho" effect is to tap the TAB key. This works great if you only need to turn it off for just one quick shallow angle, but then want it back on again after that.
I discovered this trick by accident a few weeks ago, & it has come in pretty handy since. Got to love the magical TAB button (is there anything it can't do?)
-Jon www.mds-bos.com |
1 Posts No Rating |
NO!!!!!!!!!!!!!!
Snap is NOT the same as ortho!!!!!!!!!!
How do you turn Ortho off??????
As the post above you says.... hit the tab key.
1 Posts No Rating |
How do you set this reverse? I mean...without cliking anything to have free control and if you hold TAB key down it becomes Ortho? Any help?
25 Posts No Rating |
Also make sure the 'constrain' box is un-ticked just below the ribbon.
Palm Springs Architect using Revit LT! |
0 Posts No Rating |
in Revit 2015, for me holding down the Shift key worked.
Ortho Maybe |
Mon, Jun 18, 2018 at 10:39:12 AM
ortho 3d view?? |
Mon, Jul 10, 2006 at 12:59:11 PM
''Visibility grafics'' and ''create parts'' problem when mak |
Fri, Mar 19, 2021 at 11:45:46 AM
Hiding Demo'd Garage Doors |
Wed, Aug 10, 2005 at 8:02:23 PM
Rendering without ground plane |
Tue, Dec 6, 2005 at 2:22:45 AM
