Forums >> Revit Structure >> Technical Support >> Bar Hooks length going outside the cover
Thu, Jul 3, 2014 at 10:13:09 AM | Bar Hooks length going outside the cover
Nsync
Hi,
1 - as attachment no.1 when i place a rebars the hook length is going outside the cover, why?
2 - in case of changing the bar diameter, have i change the dimension properties (standard bend diameter, hook bend diameter, stirrup bend diameter & maximum bend radius) like in attachment no.2? & is there any available bar diameters types like 18mm, 20mm with complete properties.
Edited on: Thu, Jul 3, 2014 at 10:15:18 AM
Thu, Jul 3, 2014 at 4:35:39 PM | Bar Hooks length going outside the cover
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
It looks like the rebar hook family has a large 'Extension Multiplier'. Identify the hook that is being used then find it under the 'structural rebar' category in the project browser. Double click the type itself to open the type properties and note the Extension Multiplier. The default is 10. My image below shows a setting of 50 so it's poking thru the slab in my path reinforcing.
Fri, Jul 4, 2014 at 4:23:53 PM | dgcad
Nsync
Quoting dgcad from 2014-07-03 16:35:39
I used the revit extension to rebar the footings, so some footing hooks are inside and some not, if i changed the multiplier then all changed, i want only change the footings that hooks going out.
Edited on: Fri, Jul 4, 2014 at 4:24:10 PM
Edited on: Fri, Jul 4, 2014 at 4:24:42 PM
Flexible Family Question!
Sun, Feb 17, 2008 at 4:14:47 AM
Associated Parameters in Array Family
Fri, Feb 24, 2017 at 7:27:42 AM
title bar
Mon, Sep 1, 2008 at 1:01:59 PM
Cover Sheet Components
Wed, Aug 31, 2005 at 9:30:03 AM
Applying Materials To Cover A Hole
Mon, Mar 10, 2008 at 8:26:30 PM
Page generation time: 0.2074
