Forums >> Revit Building >> Technical Support >> Unusual wall intersections in plan view
Wed, Jul 2, 2014 at 8:57:20 AM | Unusual wall intersections in plan view
Djbelanger1
In the attached images, you can see that the core of my stud walls are penetrating into the other walls, even though I have it set up as a butt joint. Moving the extent of the wall profile in elevation does not change this problem either. Has anyone run into this and know how to fix it?
Thanks!
Wed, Jul 2, 2014 at 9:11:27 AM | Unusual wall intersections in plan view
Read this topic from your HELP - it is a priority issue:
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-1CCD1005-CBDA-4338-8D60-489095D4BB25
Wed, Jul 2, 2014 at 9:20:26 AM | Unusual wall intersections in plan view
Djbelanger1
Thanks so much! This was the problem.
Wall Core Shape Edit
Wed, Nov 16, 2005 at 7:38:46 PM
Wall intersections alive!!!
Mon, May 14, 2007 at 6:12:34 PM
12
hidden line view intersections
Mon, Nov 8, 2004 at 7:58:14 PM
Arc wall spawns bizarre hatched circle wall visible in plan view only
Sat, May 16, 2015 at 3:54:11 PM
Help! 14 Meg Project in CD's slowing to a crawl!
Tue, Oct 7, 2008 at 7:57:39 AM
Page generation time: 6.8230
