Forums >> Revit Building >> Technical Support >> Cable Tray Elbow
Wed, Jul 2, 2014 at 7:57:36 AM | Cable Tray Elbow
bmoorediamond
I cannot figure out how to change the attached 90degree elbow into a 45. Can anyone provide me with a walkthru, or possibly change it while walking me thru it?
Thank you,
Branden Moore
Thu, Jul 3, 2014 at 7:19:01 AM | Cable Tray Elbow
bmoorediamond
aNYONE?
Thu, Jul 3, 2014 at 7:43:02 AM | Cable Tray Elbow
There is nothing in this family to control the angle.  The angle value is fixed.  You will have to modify it.
Look at the library family:  Ladder Horizontal bend.   It is parametric and if you want this family to be adjustable either modify that one or use it as an example to modify yours.
BTW - You don't say what Revit.  Even if I modified your family, you would not be able to use it because it upgraded when I opened it.  ALWAYS state what Revit in your posts.
Thu, Jul 3, 2014 at 8:23:38 AM | Cable Tray Elbow
bmoorediamond
MEP 2012.. apologies.
Cable tray tee
Tue, Nov 1, 2016 at 7:29:06 AM
Cable Tray Clearance
Mon, Mar 24, 2014 at 10:44:48 AM
Cable Tray- Revit MEP 2013
Fri, Oct 5, 2012 at 8:29:45 AM
Revit 2015 - Ladder Cable Tray
Mon, Feb 29, 2016 at 5:05:14 PM
How to do Cable Tray with Real Material Color (Not just filter color)
Wed, Feb 18, 2015 at 3:14:07 AM
Page generation time: 0.0208
