24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Door with window panels that can be turned on and off
This family drive me nuts. I tried doing it but everytime i put 0 on the length/width of the window panel in the door, revit deletes the whole entity.
Do you have any idea how to do this? Please tell me.
Thank you
What family?
It was a test. I failed doing it. The problem was to create a door that it's window panel can be turned on and off. Help me please
Download the Families Guide from the autodesk site. It will show you how to control visibility of family elements.
Hi Aehryl,
You may try this.
http://www.revitcity.com/downloads.php?action=view&object_id=11969
I was using the visibility to control the lights configuration.
Thank you all for your kind response. I will try everything you told me. I hope I could make this right. Thanks :3
Curtain wall Panels Pre-delevoped Adding a Door or Window? |
Fri, Jan 20, 2012 at 7:55:06 AM
Window panels that adds up! :3 |
Tue, Jul 1, 2014 at 11:11:16 AM
Can't select door/panels in storefront |
Sat, Aug 15, 2009 at 7:34:43 AM
Multi Panel Sliding door that is actually a Window Family |
Fri, Feb 20, 2009 at 7:22:04 AM
Placing window at intersection of 2 precast concrete panels |
Sat, Jan 5, 2008 at 7:57:00 AM
