Forums >> Revit Building >> Technical Support >> Design options issues
Thu, Mar 2, 2006 at 6:48:06 AM | Design options issues
Pamfi
Hi, I created some design options for the exterior and interior components of the model. And I placed the required objects on every option set from the design options. 1. How can I turn on/off on various views the design options? (I activated the view properties and I see the design options tab but how efectively can I turn them on or off?) 2. If an object belongs to a design option set is it possible to move it to a different one? (I couldn't do it) Thanks for the help, Pamfi
Thu, Mar 2, 2006 at 10:35:31 AM | RE: Design options issues
K-Pax
Pamfi We just covered alot of this over at my post on AUGI - http://forums.augi.com/showthread.php?t=34940 But to succinctly put it.... When you're in View Visibility and go the the Design Option Tab, you get a list of your Option Sets. The name of the set is on the left, with the selection of the Option on the right. This should say "Automatic" as a base, but these are pulldowns and you can choose any one you want to show. You will need to make a new floor plan view for each combination of Options you want to show - and choose them through View Visibility. IF you don't want something to show at all - just make a BLANK option within the set... and put nothing in it. Objects (walls, doors, etc....) can be moved from one Option to another Option by using Copy/Paste-in-place. You cannot just move an Option within a Set to another Set. I hope this helps, Kyle
Wall cleanups in design options
Mon, Mar 2, 2015 at 11:41:52 AM
Design Options
Wed, Dec 24, 2003 at 10:33:51 AM
Titleblocks & Design Options
Mon, Dec 8, 2008 at 2:06:33 PM
design options tied to other objects (version 2008)
Tue, Apr 1, 2008 at 6:17:36 AM
Text In Design Options
Fri, May 28, 2010 at 3:25:07 PM
Page generation time: 0.2548
