Forums >> Revit Building >> Technical Support >> Problem with wall made by "wall by face" in massing
Thu, Mar 2, 2006 at 3:51:34 AM | Problem with wall made by "wall by face" in massing
Shva
Hi, I made a mass with extrusion och after wall by wall by the face in massing. But now it's look like that the wall is not the part of building. I can not attach windows or doors to it or its not possible to attach the interior walls to it. Somebody knows what is the wrong? Many Thanks
Thu, Mar 2, 2006 at 4:11:43 AM | RE: Problem with wall made by "wall by face" in massing
eldados
eldados Avatar
4.5 Stars: 8 Votes
hard to answer without knowing the process you used... post the mass
Integrator
KarelCAD
Thu, Mar 2, 2006 at 4:15:49 AM | RE:
Shva
Quoting eldados - 2006-03-02 04:11:43
"hard to answer without knowing the process you used... post the mass"
How, do you have email!
Thu, Mar 2, 2006 at 6:22:06 PM | RE: Problem with wall made by "wall by face" in massing
eldados
eldados Avatar
4.5 Stars: 8 Votes
JUST ATTACH IN YOUR POST...
Integrator
KarelCAD
Massing Printing Problem-solve (sort of)-Revit Architecture (2008)
Fri, Aug 24, 2007 at 3:15:20 PM
wall wrapping at curtain wall "inserts"
Tue, May 20, 2008 at 6:29:51 AM
windows offset from face of wall
Fri, Jul 14, 2006 at 5:03:24 PM
Stacked Wall Flipping to other side... help please
Wed, Dec 30, 2009 at 7:37:19 AM
I can't see "Height" parameter value of Wall or Currtain Wall Schedule?
Thu, Apr 27, 2017 at 2:04:39 AM
Page generation time: 1.5181
