Forums >> Revit Structure >> Technical Support >> Construction Phases
Fri, Jun 27, 2014 at 2:16:20 PM | Construction Phases
bjenk8100
Hello,
I want to get into the phases tool of Revit.  At this point the only way I can see everything in 3D is if I model in Substructure phase.  If I make walls in interior construction I cannot see the walls in 3D.  Basically, I only model/draft in substructure.  However, I would like to draw things in different phases thinking I could organize the project.  Anywhere I can learn this would be great.  I guess I just dont understand the whole thing.
Thanks
Bjenk8100
Fri, Jun 27, 2014 at 2:21:45 PM | Construction Phases
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Who set up your phases?  Substructure and interior construction are not phases, those are areas that could go on Worksets if necessary.  Existing, New and Demolished are phases.  Take a look at this post for an example
http://www.revitzone.com/revit-fundamentals/62-phases-an-overview-of-revit-phases
Fri, Jun 27, 2014 at 2:53:50 PM | Construction Phases
bjenk8100
sorry I meant 3D views.
Bjenk8100
Fri, Jun 27, 2014 at 3:21:29 PM | Construction Phases
bjenk8100
Sorry for confusion.  This is what I mean.  I draw on a floor plan.  If you look at properties and go all the way down to phasing, A10-Substructure is selected.  If this is selected I can see everything in 3D.  If I choose C10-Interior Construction I cannot.  This template was based off of Revits Construction Template.
Bjenk8100
Mon, Jun 30, 2014 at 8:32:26 AM | Construction Phases
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
We don't use the construction template but the idea would still be the same as the link that I sent you. The reason you cant see anything when you set it to C10 -interior is because everything that you placed was placed on the A10-Substructure phase.
Phases
Tue, Aug 26, 2014 at 7:25:06 AM
Painting walls across phases
Thu, Dec 26, 2013 at 12:36:57 PM
Pads and phases
Wed, Mar 28, 2018 at 6:44:33 AM
Cutting a Column for Different Phases?
Tue, Jul 2, 2013 at 9:05:30 PM
Ghost Phases
Mon, Mar 24, 2014 at 5:08:46 PM
12
Page generation time: 0.6727
